adding BB to lift kit
Old Mar 25, 2010 | 05:08 AM
chrismarchant's Avatar
Default adding BB to lift kit
i lifted my 09 4 door with the 4.5" BDS lift about a month ago and i wanted to get a little more hight out of it. do you think putting in 2" spacers or doing the tf leveling kit would be a better idea for my situation?
thanks everyone
Old Mar 25, 2010 | 05:15 AM
mkjeep's Avatar
Is it sagging or do you just want more lift for looks?
Old Mar 25, 2010 | 05:18 AM
its a little bit of both, when im on the rocks and flexing a lot i rub here and there. but just parked its more for looks
Old Mar 25, 2010 | 05:19 AM
mkjeep's Avatar
If you just need a little, I would go with a 1 in body lift so your not screwing with all your geometry and such.or you may be able to get away with 1in coil spacers
Old Mar 25, 2010 | 05:23 AM
mkjeep's Avatar
I'm not familiar with everything in their kit, but 2in is alot to add to what you already have and may require some more mods to your whole suspensio for proper function and correct handling.
Old Mar 25, 2010 | 05:39 AM
well from what i though i understood i could go 2 more inches because i have adjustable control arms and links? make any sense?
Old Mar 25, 2010 | 06:18 AM
mkjeep's Avatar
Do you have adj front and rear track bars?or just brackets?Aftermarket driveshafts? If you just have brackets for the trackbars , you need to get adj ones to make up the difference. What kind of steering provisions do u have? Also brake lines? Bumpstops , sway links?Are they long enough? Allotta stuff to consider
Old Mar 16, 2012 | 06:08 PM
firephight's Avatar
Default saME ?
i also have this lift 4.5 BDS and want to put 2inch spacers i have adj arms and brake lines also i think the swaybar links are the same as in there 6inch kit i still have the stock driveshafts and trackbars
