Buying my first lift kit need help!!!!
Hi all i'm new here and need some help. I looked on the net for hours days and can't find what is a good lift kit for my 2007 jeed wrangler unlimited x 4door auto. I'm going to put on a 3 to 3.5 inch lift and like to get 35s on. I don't like to just ask butt i can't find any thing on this. help!!!!!!!!!!!!!!!!!!! my budget is around 1500 for the shock springs and bars. It's going to be a weeked warrior i don't know enough about it. Like from standard to flex to all the different names of lifts. I'm looking for a stong lift kit so i'm not breaking down in the bush!!! I just don't want to put %$@ in my jeep. i'm not going to be rock crawling hard with it or if any but i like to go where not alot can lol. I tryed to find a top 5 list or some thing like that and came up scratching my head lol. I looked at kits from $800 to 1450 full kits with shocks but i don't know the difference from flex to standard theres ( bds) for $1399 skyjacker for $1000 TeraFlex 3” Suspension System w/Full FlexArm System with shocks for $1450 (Systems) for $1350 with shocks. (TeraFlex JK Wrangler 3" Lift Kit with shocks ) Rock Krawler 3.5 Inch Mid Arm Flex Lift System for $998.95 no shocks i mite need drive shaft. And (bds 3"
Coil Springs $750.78) and going to need arms for this kit. And so many more. thanks for on the help.
Wow lot of info. Advice try breaking it up so it makes it easier to read.
Most people hear would recommend Teraflex brand. High quality and customer support. If you are not going to go rock crawling you might want to just consider the Tera 2.5.
I have the Zone Offroad 3" kit with 35s. Similar use to what you describe for about 6 months, and it works well for me. It is way cheaper than some your are looking at.
If hear good things about the other kits mentioned above as well.
-wwiifirearms
-wwiifirearms
I agree call Dave at Northridge. I wanted the same as you and went with the TF 2.5 coil lift , adjustable trackbars, and front lower control arms. Spent way less than $1500 and am running 35's with no issues. The ride is great.
* spring/shock lift kit (T/F or OME)
* track bars
* front lower control arms
Also consider adding:
* T/F steering stabilizer (cheap)
* sway bar links (cheap)
* JKS quicker disconnect (sorta cheap)
If you go too high you'll be looking at drive shaft and front upper control arm issues, brake line extension, etc. It would be nice if all the various paths were mapped out on a flow chart somewhere, but they're not.
Conventional wisdom is that something like a T/F 2.5" lift (which will get you closer to 3.5" on a 2-door), track bars, and front LCAs is a sensible upgrade path.
