I'm torn between?
Old Mar 27, 2010 | 10:33 AM
Xtreme545's Avatar
Question I'm torn between?
I'm torn between buying the Rubicon Express 2" spacer system with twin tube shocks or the Teraflex 2.5" budget boost kit with adapters? I'm pretty new at lift kits and was wondering what is the best "bang" for my buck? Any help is appreciated!
Old Mar 27, 2010 | 12:40 PM
Ericker's Avatar
Teraflex seems to be real popular on here.
I've heard alot of positive things about the Teraflex and also that their customer service is great. I have the Teraflex leveling kit and though there are not many parts I think the build quality is good.
Old Mar 27, 2010 | 12:57 PM
glwood6's Avatar
For around $500 you are going to get four spring spacers, four shocks, and four bumpstop extensions with the RE kit. If you want to get rid of the rake, this will help even out the JK, because the rear spacers are .75" taller than the front:
With the Teraflex basic BB for $338, you get four spring spacers (all 2.5", no rake leveling), four bump stops, longer rear swaybar links (you can move your stock rear swaybar links to the front, they are longer), rear brake line brackets, four shock extensions, rear frame mounted track bar drop down bracket. Just the cost of this kit alone with all the extras seems more bang for your buck. If you add four shocks for $145, you are still under the cost of the RE BB, and have a lot more for your money. IMO
Old Mar 27, 2010 | 12:59 PM
4drsahara's Avatar
After lots of reading and suggestions for the guys on this forum, i have decided on the TF BB. I will be ordering it on Monday
Old Mar 27, 2010 | 01:04 PM
glwood6's Avatar
With shocks or without?
Old Mar 27, 2010 | 01:12 PM
4drsahara's Avatar
Without for now, i will upgrade the shocks later on when i upgrade to a larger lift.
Old Mar 27, 2010 | 01:15 PM
glwood6's Avatar
You'll like this setup. I ran it for a couple of years, and was happy with the ease of installation as well as the quality of the components.
When I changed to an OME spring lift, I kept the bumpstops, brake line brackets, and longer swaybar links in the rear from the TF BB.
Old Mar 27, 2010 | 03:59 PM
jrmotorsports81's Avatar
You may want to look at the 2.5 " terra flex coil lift instead of the pucks.
Old Mar 27, 2010 | 04:53 PM
RN M OVR's Avatar
I agree on this statement. If you are going to go 2.5" then why not do the Teraflex coils or Old Man Emu. Otherwise, you should do the Rubicon Express 2" with Teraflex quick disconnects. I have done some seriously wheeling with my 2" and it is awesome, especially with the disconnects.
What size tire do you plan on running? Do you have a 2dr or 4dr?
Old Mar 27, 2010 | 07:02 PM
0llll0's Avatar
Go with the old man emu kit, it gives you plenty of lift and the ride is great! I run the hd kit in my 4 door with the hardtop and 35's. The price is good as well.
