Smittybilt SRC rock rail install
Old Mar 27, 2010 | 08:42 PM
rubi08unlimited's Avatar
Default Smittybilt SRC rock rail install
Has anyone else had issues installing these? the driver's side went on rather quickly except the body mount washer was in the way so I couldn't get on of the stock nuts back on. on the passenger side, I could only get one of the nuts on and the other 3 were either blocked by the washers or there wasnt enough room between the stud and the inside wall of the rail mount to fit a socket (or the stock nut for that matter). after much prying, i was able to get one nut on front and back and I'll take another stab at the others when i can get some more tools. Any tips or tricks to these or did I just get a bad batch?
Old Mar 27, 2010 | 08:50 PM
renpia's Avatar
Unfortunately this is a common problem with the SRC. I installed mine not too long ago. The driver side went on with some prying but the passenger side was a PITA. I was able to get the front two bolts on and one on the back and I had to grind the hole larger to get the nut to align with the bolt. Even then, there was still a lot of prying. I think I even cross-threaded the last bolt. Oh well, I just tightened that bad boy as tight as I could. At the end of the day, they look great and feel rock solid.
Old Mar 27, 2010 | 09:00 PM
SoccerMan1080's Avatar
i had the same exact problem... had to grind out one side of the rock rail that mounts to the body and pry that sucker on there... it was such a tight fit that the socket i used to tighten it got stuck and is still there in the hole... but i did manage to tighten it... such a hassel but they look great.
Old Mar 28, 2010 | 04:13 AM
BLK-JK23's Avatar
pics of install!!
