how to stop Sway bar from extending over center?
Old Mar 28, 2010 | 08:14 PM
Brashanic's Avatar
Default how to stop Sway bar from extending over center?
my link is a pretzel. i will fix tomorrow. how can i fix it so it doesn't happen again?
Old Mar 28, 2010 | 08:17 PM
bareass's Avatar
unbolt it from the axle!
Old Mar 28, 2010 | 08:19 PM
Brashanic's Avatar
it's a Rubi. it disconnects. should i put quick discos on it?
Old Mar 28, 2010 | 08:20 PM
Brashanic's Avatar
after i pounded it straight
Old Mar 28, 2010 | 08:22 PM
Brashanic's Avatar
Default before i bent link
not overextended here. but close. i did it not long after this picture.
Old Mar 28, 2010 | 10:22 PM
Yom's Avatar
Yom
Apart from limiting straps to prevent suspension movement there is no real way of resolving this particular trait of a swaybar which works in an opposite arc to that of the axle.
Or fit disconnects!
Old Mar 29, 2010 | 05:49 AM
Littlejon's Avatar
You can get longer sway bar end links, or quick disconects and manually disconnect.
Old Mar 29, 2010 | 06:58 AM
randyd's Avatar
More the question. If its a Rubi, why is it doing that? Something might be letting your suspention travel too far. Are your shocks stock Rubi? If not are they matched to the lenght of the sway bar links???
I have a Rubi with the TF2.5 coils. Never had a problem.... Yet!!
Old Mar 29, 2010 | 07:12 AM
GoodysGotaCuda's Avatar
Where does the bar sit when the jeep is on all fours/flat? Needs to be pretty darn close to parallel to the ground if you have the right length links.
Old Mar 29, 2010 | 07:27 AM
yomondo's Avatar
Originally Posted by Littlejon
get longer sway bar links
x2 on both of these comments.
