4:1 Kit for a JK?
I have looked at a few tread`s to find the answer to the question........
Does anyone know if there is a way to change the gears in my 08 Sahara T-Case to make it a 4:1? And have not found anything.
I have the 6 speed trans also.
In the not so near future I plan to put a 44 up front. But for right now I am looking to get alittle more crawl out of my jeep with out changing gears. Don`t want to spend the money to re-gear the dana 30 then have to buy another set when I put the 44 in.
You can find used Rubi cases for $600 or so, if you look around.
Or a RubiCrawler from Advance Adapters (though I think this is just for auto's?) $1600
Or just move up to an Atlas. $2200-$3200 ish
I was just thinking about this yesterday as I too have a Sahara and was pondering swapping in a Rubi T-case. Is it a direct bolt in for the 6 speed, are there any other Rubi specific wiring harnesses or anything like that?
Nope. I have a X and swapped in a Rubi case into. Nothing needed for the wiring or electronics.
