Bent Tie Rod - Best replacement option?
What are the issues driving with a bent tie rod, does it hose the alignment?
Whats the pro's/cons in replacing with a complete assembly, versus others that do not include the ends?
Worried if replacing with an 'unbreakable' assembly what would be the next weakest link that would break?
Last edited by HappyCurmudgeon; Mar 30, 2010 at 09:37 AM. Reason: blacklist mention.
I went with the Rockrawler HD tie rod after I bent mine. I did have to go out and buy the moog rod ends for it which definately added to the cost. The one thing that I know about the Rockrawler is that is super beefed up. I think it would almost be impossible to bend that one unless your Chuck Norris.
HUH?
"...designed to accept OEM Tie Rod Ends at the pitman arm...
* Requires the purchase of two OEM Tie Rod Ends from the JK stock drag link at the Pitman arm location."
accepts OEM ends, but they must be purchased?
the rock krawler tie rod is just the beefed up rod. you need to buy the replacment ends from the dealer... or napa.
The stock tie rod ends will be no good if you go with the rock crawler tie rod par. You will have to purchase 2 DRAG LINK ends that attach the the pitman arem of the steering box. They are beefier, I would stick with the OEM parts as the after market ones I have seen fail. The part number for the OEM draglink end is 52060049AE. Remember you will need 2 of these. If ordered from a sponsor on here they aren't that bad of a price. Hope this helps.
thanks for the diagram!
i crushed mine on rock and actually dented my front diff cover - was in some mud and crawling over rocks slowly was not an option. it's always fun breaking stuff, plus it keeps all the good folks at Tera, RK, Currie, etc employed!
thanks again
thanks again
thanks!
ordered the Rockrawler HD Tie Rod and Mopar ends. WOL actually has a nice write up on this install too.
