My fender chop
Looks awesome.. What did you use you to cut the fender, and I can't tell but does this involve removing some of whatever plastic is under the fender? last question.. Do the fenders still feel pretty sturdy? Just want to know before I do a hack job in my jk, thanks
You can check this link for a write-up on doing this. There are also several others so do a search for Fender Mod" to find more info. I used a 4 1/2 " cut-off wheel to cut mine and then a dremel cut-off wheel to cut the turns. Yes, you'll need to remove the fender liner and the sub-stucture to do this mod. If you wish you can trim and reinstall both of these pieces after you trim the fenders. I reinstalled both. No, the fenders aren't very sturdy once you do the fender mod.
http://project-jk.com/jeep-jk-write-...ry-fender-chop
