smittybilt xrc10 comp in RR XHD winch bumper
Old Mar 31, 2010 | 08:31 PM
rubi08unlimited's Avatar
Default smittybilt xrc10 comp in RR XHD winch bumper
is anyone else running this combo and did you have problems with the winch not lining up with the slot in the bumper? I had to use the holes to the right so the drum of the winch is shifted approx 2 inches to the right of the slot. If I use the holes that would allow the winch to be centered to the slot, the backing nuts that hold the hawse fairlead on are in the way of where the winch needs to sit. should I have an adapter plate for this? I had a hard time getting the line on because the line would not get to the right side of the drum without me guiding it with my finger which I'm not really comfortable with. Any ideas????
Old Apr 1, 2010 | 01:39 AM
Olean NY Jeeper's Avatar
I have that bumper with the XRC 8 and had not issues when I followed the instuctions. Did you put the fairlead nut on the outside or the inside? The directions state the bolt goes from the inside out with the nut on the outside.
Old Apr 1, 2010 | 06:02 AM
knyland's Avatar
I got the XRC 10 comp and low and behold the F'n hook on the front only has a working load limit of 4k I am dealing with Smitty built right now to correct the problem. If they dont i will put a different hook on rated to 10k that should only cost me 100 bucks for the hammerlock and hook.
Old Apr 1, 2010 | 06:29 AM
JerryJeff's Avatar
Default Yep, I had the same problem...
I have the exact same set up and had the same issue. I went to Lowe's an got some shorter bolts for the fairlead, problem solved.
Old Apr 4, 2010 | 04:05 PM
i did not follow the instructions. I'll have to look again. the nuts were square which i found odd but now that I think about it, i guess they would recess into the fairlead... I'll check it out tomorrow...
Old Apr 4, 2010 | 04:11 PM
brandonbooth's Avatar
The square nuts are supposed to go into the feet of the winch... and with the rollers i had to put the nut on the outside as well to get it to fit. I just installed mine a few days ago and it went all smoothly. Did you have square nuts for the fairlead too?
Old Apr 4, 2010 | 04:20 PM
yes, all square nuts
Old Apr 4, 2010 | 08:06 PM
MrMoJo's Avatar
Same issue. After reviewing the thread I reviewed my instruction multiple times. There is no suggestion on how to install the bolts on mine. Assumed the hex head was on the outside. Cleaner look. I have the same issue with the winch mount. Guess I will swap out the bolts and move the winch.
Old Apr 4, 2010 | 08:30 PM
now I don't feel so bad at least untili i go to do it and the square nut wont fit in the recess...
Old Apr 5, 2010 | 03:22 AM
knyland's Avatar
Originally Posted by ECHO
How did you figure that out?? want to make sure I don't have the same Hook
big fat WLL 2tons right on the hook. WLL stands for working load limit wich means that is the weak link. I am waiting on a call back for about 4 days now I will give the the benefit it was easter weekend but I will call today. if no love I am calling the rigging store I use for work to sort out the hook and hammer lock.
