Will 35's fit with 1" coil spacers temporarily?
Old Apr 9, 2010 | 09:52 PM
dustdriver's Avatar
Default Will 35's fit with 1" coil spacers temporarily?
Will 35's fit on my Rubi with just 1" coil spacers? Long enough to get me to the shop for the lift?
I'd be looking at about 5 hrs of freeway from the tire shop. Just trying to figure out some logistics. Not sure if they'd be undriveable without further modifications, or if they'd be fine for a day of pavement.
Old Apr 10, 2010 | 01:35 PM
jvalason's Avatar
You should be fine if your only driving there...just dont hit speed bumps!!
Old Apr 10, 2010 | 04:43 PM
Stuka's Avatar
You should be ok, just watch any bumps and such. The other option is to drive their on stock tires, and then put on your 35's once you get home.
Old Apr 10, 2010 | 07:22 PM
RubiDude's Avatar
Local shop put them on a stock X no problems...on the road! I would not go off road or hit a speed bump!
Old Apr 26, 2010 | 07:10 PM
dustdriver's Avatar
Just a quick followup:
YES the 35x12.5 BFG KM2's will fit with the 1" TF kit, as long as you are keeping it on flat ground. I rubbed a fender well once when crossing a railroad track in a shallow dive, and there was very light rubbing on the lower front control arms at full steering lock (17x8, 4.25 BS). Thanks for the advice guys, you were spot-on.
35's with 1" coil spacers:
Close-up:
For comparison, here it is with the 4.5" RE lift and NO spacers:
Old Apr 26, 2010 | 07:13 PM
Vrrooom's Avatar
Any pictures of the back clearance on the factory rock rails?
Btw, thanks for the follow-up, it always helps to get confirmation to speculation.
Old Apr 27, 2010 | 05:41 AM
dustdriver's Avatar
Originally Posted by Vrrooom
Any pictures of the back clearance on the factory rock rails?.
With the spacers only? Not the kind of close-up you probably want, but here is a zoom from the high-res, taken at a slight angle:
The clearance there was small, but never caused any issues in the few days I ran it in that configuration. Even with the lift, the clearance there isn't much, and I will probably go ahead and ask a friend with a plasma cutter to trim the rail back, flush with the wheel well.
