Tires rubbing flares/wheel well/part of frame(?)
I have a 3" Black Diamond lift, and I am running 35" (technically 34.5" when new and 32.5" as of right now) tires. Yesterday, I tried to go up a hill and felt my left rear tire rubbing up against the wheel well/fender. See attached picture for a visual.
Also, when the rear tires were "new", they would sometimes come into contact with the piece of metal that I circled in red (second picture). The tire is worn now ... smaller in diameter ... so it is no longer an issue, but it will be again when I replace the tires.
Does anyone have any thoughts about all of this? I am not sure what to do. New fenders (or chop stock ones)? Add spacers? Body lift?
Please help. Thanks!
-Dawn Marie
-Dawn Marie
The second picture with the red circle is the pinch seam. Trim it down or hammer fold it over so you don't puncture your tire. Your picture of the tire at full flex looks like it's contacting more than just the outside edge of your fender flare, but I can't really tell. If it's just contacting the outside edge trim it to size (or buy new flares). If it's slamming into the entire underflare plastic area you may want some extended bump stomps.
btw, nice setup
btw, nice setup
OK, I'll have to look into modding the pinch seam. Thanks for the advice. I did a search and I see that several others have done the same thing.
Thanks! Still more to come. LOD rear bumper and tire carrier came in the mail today, so looking forward to having it installed in a few days (when the rest of the parts come in ... grrr).
