Adding a 2.5" coil lift and have a few questions
Old Apr 27, 2010 | 09:06 AM
The Hawk's Avatar
Default Adding a 2.5" coil lift and have a few questions
I am adding a 2.5 Coil lift (from littlejon) and was wondering.....
it comes with the coils, shock extenders (for now) ... and a track bar relocation bracket.
Any other parts need moding , altering?
Is there anything else i need?
Thanx in Advance
Old Apr 27, 2010 | 09:59 AM
frankie945's Avatar
extended bump stops
Old Apr 27, 2010 | 10:12 AM
Xtreme545's Avatar
Brake line drop bracket too
Old Apr 27, 2010 | 10:16 AM
Calypso's Avatar
You will want to move your rear sway bar links to the front and buy longer ones for the rear. Also, if you have a little extra $, adj trackbars will keep you from having to use re-location brackets that tend to weaken the already under par trackbar supports.
Old Apr 27, 2010 | 03:42 PM
Cpt. Flapjack's Avatar
The complete lift contains:
Front coils
Rear coils
Rear trackbar relocation bracket (with inner spacer tube)
Rear brakeline brackets
front bumpstops
rear bumpstops
front shock extensions (with 2 large fender washers)
Rear shock extensions
Rear swaybar links
These might only come if you get the longer shocks:
Rear 1/2" spacers with guide post
Rear spring retainers
Did I miss anything anybody?
Old Apr 27, 2010 | 03:58 PM
Livelife4winter's Avatar
Front coils
Rear coils
front bumpstops
rear bumpstops
Rear swaybar links
cam bolts or adjustable control arms??
i did a 2in lift and i replaced all my control arms with currie rock jocks....a bit over built but when you do it right you don't have to do it again hopefully ha
Old Apr 27, 2010 | 04:22 PM
They arn't included with that Teraflex lift and at 2.5" really not "required". That said, control arms are deffinatly nice to add on to dial in the front and allow for aftermarket rear driveshafts down the road.
