Jerry Cans
Old Apr 30, 2010 | 05:37 AM
McPuck86's Avatar
Default Jerry Cans
Really. Why am I having SO much trouble trying to find a jerry can/rack for the JK? I am looking for the one that has two cans, one on each side of the spare with the rack on top. Can't seem to find it anywhere.
I do not want one where I have to have "their" bumper.
Any help or ideas????
Thanks!
Old Apr 30, 2010 | 05:41 AM
rob7765's Avatar
I don't think anyone makes one that will fit "any" bumper and I wouldn't advise putting one on that attaches to your stock tire mount or tailgate. Putting two Jerry cans full of fuel would add more than 80 lbs to your tailgate plus whatever you put on your rack plus your spare would equal disaster.
Old Apr 30, 2010 | 05:53 AM
McPuck86's Avatar
Thanks for the info ... but where is a good place for the cans???
Old Apr 30, 2010 | 06:05 AM
wayoflife's Avatar
JK-Forum Founder
you can get basic blitz cans from 4wheel parts. their main warehouse in compton right off the 91 is your best bet if you need them right away. if not, you can get nato cans online.
Old Apr 30, 2010 | 06:13 AM
McPuck86's Avatar
But where to mount them?
Old Apr 30, 2010 | 06:16 AM
wayoflife's Avatar
JK-Forum Founder
i run an lod bumper and got it with the jerry can mounts and trail rack....
http://www.northridge4x4.com/proddet...TC1001&cat=293
this is what the jerry can mounts look like...
http://www.northridge4x4.com/proddet...1004G2&cat=293
Old Apr 30, 2010 | 06:51 AM
Dirty Dog's Avatar
How about those flat gas containers?
Old Apr 30, 2010 | 08:21 AM
sm_rubi's Avatar
The flat gas containers like rotopax can be mounted in front or in some cases behind the spare tire. I'm running the military style Nato Containers but to be California CARB compliant the MFG (Wedco) uses a threaded cap. "Unlike the standard jerrycans, the CARB compliant Petrol jerrycan features a threaded mouth." Which sucks and actually does spill so not sure I'd recommend those.
Best mounting for the Jerry Cans is with a Jerry Can mount of some sort (see WOL links).
*update*
After using there "plastic" spout I'd have to say this thing doesn't leak while fueling only leaked on me when on the mount and running off-road but I found the cap wasn't too tight either so I'll hold off my distaste for the Wedco CARB cans for a while.
Old May 1, 2010 | 02:16 PM
azrwilkinson's Avatar
Onother option is the OR-Fab rear tire/gerry can holder, it will even have a spot for a high lift as well. Just another suggestion. Good luck on this!
Old May 1, 2010 | 02:55 PM
JKMoses's Avatar
This is the Or Fab tire/can holder. I hope you have a good selection
