Lockers when I want them
Is there a way to engage the factory lockers on a 2009 Rubicon in high gear. I found out I can do it with my super-chip but you have to keep the controller plugged in all the time.
That was a great write up, love the pictures. One more question, how did you remove the esp? There has been several times when I was rock crawling and bent the tie rod or drag link and that threw the steering wheel out of center so when you drive the jeep it slows down. I have had to stop and use the book to disconnect the esp till I got the wheel centered.
I just perminently disabled the esp with the instructions from the owners manual. Although the BLD is still active which is a bit of a pain but I do pretty much all my offroading in 4lo it is just easier on everything
