Teraflex Compatibility With Right Hand Drive
So I'm itching to pull the trigger on a nice big Teraflex build. Lift kit, 8 FlexArms, Monster HD Front Trackbar, Rear Trackbar, the works.....
But I'm thinking I may run into trouble with the track bars. The trackbars on the RHD Jeeps are mounted on the opposite side to the LHD Jeeps. Will this affect the mounting of the Teraflex trackbars in any way? Potentially lame question here, but will the trackbar bracket that comes with the 2.5" coil lift work with RHD, or don't you need the bracket if you install a rear adjustable trackbar?
I'd really like to install Teraflex, and it'd be a bummer if RHD is an issue.
If it is, would it be possible for Teraflex to make me custom trackbars that'll fit my Jeep?
I won't mind paying extra, even a lot extra to make it work.
Thanks in advance
Estian
Thanks in advance
Estian
TeraFlex has a RHD rear axle trackbar bracket for the 3"+ kits. I'm betting that the standard 2.5" TB bracket #1954202 will work in yours. Post up a pic of your rear trackbar and the mounting locations so I can take a look if you can.
you WILL run into problems with the rear trackbar. the RHD rear trackbar is longer than the LHD. i know for a fact that Full Traction can make one for you. they used my stocker to make a jig, and can now make what you need.
edit: let me clarify one thing... my JK is an '08 2-door... not sure if they changed anything with later models.
Now posts some pics of your two door
