Question about teraflex 2.5" coil lift
Old May 3, 2010 | 10:27 AM
Doc_D's Avatar
Default Question about teraflex 2.5" coil lift
I have a teraflex 3" lift on my '08 2 door soft top. I got a TON of lift out of it. It looks great but I'm thinking of going to the 2.5" coils to get the steering geometry a little better and to keep my drive line a little happier. My understanding is that I'll end up with a true 3" of lift if I got with the 2.5" coils.
Does anyone know if I'll have to change anything else out? I'm assuming the bumpstops should still be fine, correct? The 3" kit did come with a front a rear spacer if I remember correctly. Does the 2.5" kit also come with these spacers or should I pull them when I go to the 2.5" coils?
Thanks!
Doc
Old May 3, 2010 | 10:41 AM
RevyJKU08's Avatar
I am sure a few people with this lift and 2 dr will chime in. ECHO should chime in as he went this route with his 2 dr.
From my reading threads about the 2.5" TF coils. I recall the 2 dr got at least 3.5" of lift with a 2.5" coil spring lift. If you go with the coil spring lift, you will want to pull out those spacers Unless one is 1/2" spacer then you could pop it into the front to level the stance out.
Old May 3, 2010 | 10:42 AM
RevyJKU08's Avatar
Obviously with your current lift you must have changed your drive-shaft, front lower or upper control arms, track bars, rear swaybar links.
Old May 3, 2010 | 06:35 PM
StripyMonkey's Avatar
X2 giving Joe a call. TeraFlex now has 2 door springs in all sizes. So you can dial in the amount of lift a bit more.
