whats with all the parts in the Mopar 2" lift kit...
Old May 3, 2010 | 07:44 PM
jerseyoifvet's Avatar
Default whats with all the parts in the Mopar 2" lift kit...
can anyone break bown the purpose of all the parts that come with the mpar 2 inch lift... im new to the work of mod's and im trying to learn the ins and outs of the suspension...
Old May 3, 2010 | 07:47 PM
stlfan06's Avatar
https://www.jk-forum.com/forums/show...ery-Newbie-Has
Old May 3, 2010 | 10:55 PM
nthinuf's Avatar
Yep, faq's are a good place to start. And copy the top pic here to your desktop for reference.
http://project-jk.com/jeep-jk-write-...-end-alignment
But...
MOPARŽ Performance 2" Lift Kit with Bilstein Shocks
* Coil Springs
* Front Track Bar (axles are pushed over to one side after a lift, this re-centers them)
* Brake Line Brackets (brake lines are stretched too tight, these give them more room)
* Cam Bolts (front caster is too low after a lift, causing flighty handling and bumpsteer - these are arguably the worst of the 3 options for correcting caster)
* Rear Track Bar Bracket (same function as the new front trackbar, but it's a spacer bracket instead of a new bar)
* Steering Stabilizer (heavier duty than stock)
* Shocks (longer than stock)
* Sway Bar Links (after the lift, your swaybars will be pointed down, you want them level, so new longer links)
* Bump Stops ( prevent tires from contacting the fenders, and prevent the coils/shocks from over-compressing)
Old May 3, 2010 | 11:03 PM
spinlock's Avatar
Parts Included:
Coil Springs
Front Track Bar
Brake Line Brackets
Cam Bolts
Steering Stabilizer
Shocks
Sway Bar Links
Bump Stops
Old May 11, 2010 | 01:02 PM
Originally Posted by spinlock
Parts Included:
Coil Springs
Front Track Bar
Brake Line Brackets
Cam Bolts
Steering Stabilizer
Shocks
Sway Bar Links
Bump Stops
thanks guys... next time i will definitly look before i ask..
