Question about swaybar links
Old May 4, 2010 | 04:57 PM
JK-Tex's Avatar
Default Question about swaybar links
Is it correct, when installing adjustable swaybar links in the rear, to move the stock rear links to the front? I've heard they're longer, and will thus provide some (marginal) benefit if you put the rears up front. Thanks, folks.
Old May 4, 2010 | 05:11 PM
Bowman's Avatar
Yes, that's correct.
Old May 4, 2010 | 05:14 PM
nthinuf's Avatar
Depends on the lift height. (didn't see a lift in your sig) With most mild lifts, it is common to move the rears up front to keep the swaybar parallel to the ground. If you don't have a lift, putting the longer rears up front may have the bar pointing to far up.
Old May 4, 2010 | 05:53 PM
JK-Tex's Avatar
Thanks. Installing a NR4X4 OME lift (standard springs) this weekend. This answers my question!
Old May 4, 2010 | 05:59 PM
JK Rocker's Avatar
In my experience, most small lifts come with new rear links, and you move the stock rear links to the front, since they are longer, which is needed after a lift. If you have a lift that did not come with new rear links, either you don't need them because the lift isn't significant enough, or the lift simply didn't come with them (which I doubt is the case).
If you are installing adjustable quick disconnects, you will want them in the front since you really should not disconnect your rear sway bar. In that case, you should leave the stock ones on the rear.
Old May 4, 2010 | 06:01 PM
JK Rocker's Avatar
Darn, you replied while I was typing.
Yeah, then you should move the rear links to the front and install new rear links.
Old May 4, 2010 | 06:04 PM
JK-Tex's Avatar
Whoops. I do have JKS Quicker Discos to install as well, and see now that these REPLACE the front links. So, new adjustables in the rear and discos in the front. The joy of being a shade tree mechanic is that you're constantly learning as you go.
Old May 5, 2010 | 11:39 AM
JK Rocker's Avatar
No problem. Your lift kit will probably come with new rear links. Just put your JKS links on the front and the new ones on the back. You will need to adjust your front links so that the sway bar sits level.
