ARB on-board
Old May 4, 2010 | 05:25 PM
crawlermike's Avatar
Default ARB on-board
where to mount under the hood?? any help or pics.
thanks mike
Old May 4, 2010 | 05:26 PM
ClownPoop's Avatar
just like this:
Old May 4, 2010 | 05:30 PM
what is it mounted to? did you fab something up?
Old May 4, 2010 | 05:33 PM
ClownPoop's Avatar
It's a bracket that's sold to mount the compressor in the JK's... got mine in a package from northridge... I think others sell it by itself if you search it out... If I recall it's not cheap on it's own...
Old May 4, 2010 | 05:35 PM
OnBelay's Avatar
I mounted mine a bit differently. My tank is on the other side of the compressor and the solenoids are pointed towards the driver's side wheel well. I wanted to keep those air lines as far from the engine and manifold as possible ...
Anyhow, my (and I also assume crawlermike's) compressor is mounted via a mounting plate that attaches to the bolts that secure the brake booster. You can get it from David at Northridge4x4. Another vendor sells an identical unit, but I cannot remember the name of it. BTW the mount is a PITA to install, but worth it in the end.
Old May 4, 2010 | 06:04 PM
JeepItm8's Avatar
Has anyone mounted on onboard tank? Pictures of where mounted also?
Old May 4, 2010 | 06:08 PM
OnBelay's Avatar
Lots of people do it, but the question is "what do you want to do with it?" The ARB only puts out 75-95 PSI, which is too low for running air tools, etc. It will fill up tires fairly well though. Yes you can modify the pressure switch so that the compressor puts out 145+ PSI, but I believe that is too much pressure if you plan on running ARB air lockers off of it.
Old May 5, 2010 | 01:40 PM
Dozilla's Avatar
Here is mine, all purchased from David at Northridge 4x4.
Old May 5, 2010 | 05:01 PM
thanks for the info
