Driving w/ overdrive off sucking fuel?
Old May 4, 2010 | 05:33 PM
JeepItm8's Avatar
Default Driving w/ overdrive off sucking fuel?
Eversince going big it sucks driving on highway in oerdrive as it is constantly shifting in and and out of. So I just drive with it off.
I know I need to re-gear but need more $$ so I can install lockers at the same time. Until than Am I gonna cause any problems other than wasting fuel?
Old May 4, 2010 | 05:37 PM
nthinuf's Avatar
Driving O/D Off should actually cause less strain on the transmission, as it puts you in a better overall ratio. And at a guess, you'll get better mileage with it off as opposed to lugging the engine and constantly dropping out
Old May 4, 2010 | 05:47 PM
JeepItm8's Avatar
Thanks for the reassurance that's what I thought. Just trying to post anything and everything I can. Even dumb nagging questions just to lose this newbie tag!
Old May 4, 2010 | 05:52 PM
sixt7gt350's Avatar
This is absolutely true and confirmed.
With stock sized tires and 3.73 gears, the Jeep wants to hunt for OD between ~40 and ~50 MPH.
Leaving it out of OD for trips in that speed range, I was able to repeatably get better MPG.
The key to good mileage is not getting the engine much above 2K RPM, at which point the fuel starts to disappear in a hurry.
By hunting for gears, your RPM will surge above 2K pretty much every time the lockup disengages to allow the shift.
Old May 4, 2010 | 07:08 PM
jcole's Avatar
Which gears does the converter lock up in ? 3rd and 4th ? It would be nice if it could lock up in first for crawling in 4lo, then maybe unlock if you touch the brakes.
Old May 4, 2010 | 07:30 PM
ronjenx's Avatar
3rd and 4th. I'm not sure if it will lock in 3rd, if O/D is allowed.
I have never seen mine lock with the selector in 1st or 2nd.
