15" wheels that fit without grinding?
Months ago I saw a thread about 15" wheels that had the proper back spacing for 12.5 width tires and didn't require any grinding of the brake caliper. I've searched and can't find it. I'm looking to go from 17" down to 15" .
Thanks
Thanks
What is the reasoning behind putting a 15" wheel on a jk, it's not designed to have that small of a wheel, the price difference between 15 and 16 is minimal. I just don't see the point in grinding down the calipers?
I think a lot of it is just the remnants of old school thinking where 15" rims were the De facto standard on off road 4Xs. Ironically, many wanted and needed larger brakes to effectively stop the big rubber which required larger rims.
Maybe several reasons for the 15" wheels. Cheaper tires, cheaper rims for rock crawling, taller sidewalls and load range C so smoother (squishier) ride when aired down.
I have been running 15 inch 35 X 12.5 MT/R Kevlars on Procomp Rock crawler rims and they are working great but there was slight interference with the Rubicon front brake assemblies. Used a die grinder to take ever so small amount of materiel off and they are just fine.
this is what i read and purchased them from discount tire direct. they are great. tires are cheap. they look bad ass
https://www.jk-forum.com/forums/show...-VS-15x8-Steel.....
MB Razor 15x8 -19mm offset fits without grinding
MB72 15x8 -19mm offset fits without grinding
MB Chaos 5 15x8 -19mm offset fits without grinding
https://www.jk-forum.com/forums/show...81#post1781481
Link to prices and availability: http://www.discounttiredirect.com/di...wheels/home.do
