Installed lift, now ESP / BAS warning light is on
I installed the OME lift this weekend (coils, shocks, adjustable track bars, sway bar links). All went relatively smoothly and I'm very happy with it.
But now the ESP / BAS warning light is on, indicating the electronic stability program is no longer working. I was careful to loosen or free up wires, brake lines, etc when lowering the axles to not stretch or damage anything. So I'm not sure what happened...
Any ideas?
Any ideas?
I'm about to install my lift, and I think other have had this issue when their steering wheel hasn't been straightened perfectly after a lift. Then I think you need to drive around for awhile for the light to go off.
I may be wrong though, I would do a search, there are a ton of threads on this issue that may be able to help you.
You should get it proffesionally aligned and the steering wheel centered. I had this issue after I put my lift on. I had centered the steering wheel the centered the best I could...obviously wasn't good enough. Took it to get it aligned and it fixed the problem. Have never had an issue since.
Once I got my allignment, it went away for me as well. Just a note now that on freeway on and off ramps, I have to slow down quite a bit more than I did before or the system will kick in and the brakes spaz out. Getting more used to it but it was terrifying at first.
Here is my theory why caster matters when it comes to ESP issues. I think your steering has some play in it. You can move the steering wheel back and forth from the center point quite a bit before it actually moves the tires. When you have enough caster, when you are turning to the right the wheels are pushing back left and they take the slop/play out of the system. Likewise when you are turning left the caster forces the wheels back to the right taking up the slop or play in the system. When you don't have enough caster and you are in a turn the wheels aren't being forced back to the center. Both the steering wheel and tires can move around in that area of play/slop. That can cause the difference between the steering angle and between the vehicles direction of travel to be large enough to cause the ESP to fire.
I have had a professional alignment and that got rid of the deathwobble and the ESP light around all corners, now it is just certain ramps that I have issues. The one thing I have not done yet is reflash the computer with the bigger tires. Only put 33's, I know I should do it sooner rather than later. Wonder if there is a mismatch in the computer that causes it to think there is issues?
