which heavy duty steering stabalizer ??
Old May 17, 2010 | 06:47 PM
genzod's Avatar
Default which heavy duty steering stabalizer ??
should i get the terraflex,orv,ect ?? not sure,thanks
Old May 17, 2010 | 06:48 PM
phayden's Avatar
Check AEV.
Old May 17, 2010 | 06:54 PM
jvalason's Avatar
If you stock one isnt leaking or trashed dont waste the money on a "hd" one.
Old May 17, 2010 | 07:04 PM
mwbmorley's Avatar
Default SkyJacker Dual Steering Stabilizer
I just finished installing the SkyJacker Dual Steering Stabilizer this past weekend. Real easy install, looks cool under the JK and works real well. It was just realesed about a week ago and was reasonably priced.
http://www.4wd.com/productdetails.aspx?partID=55734
Old May 17, 2010 | 07:43 PM
yafoz77's Avatar
After destroying the stock one I spent too much time deciding on a stabilizer. Due to availability etc I went with a SkyJacker (single).. truth is: It works great! Looks good, does the job and costed less. Perfect. If you wheel use a relocation bracket like the "woods".. otherwise, yours will end up looking like mine..
Old May 17, 2010 | 08:02 PM
*Seth*'s Avatar
I love my Rough Country dual steering stabilizer setup.
Old May 17, 2010 | 08:03 PM
wayoflife's Avatar
JK-Forum Founder
couldn't agree with you more.
Old May 17, 2010 | 08:48 PM
spinlock's Avatar
x2. But if it is trashed then either OME or Bilstein.
Old May 18, 2010 | 01:05 AM
jcole's Avatar
I use the Rough Country dual setup. Looks neat, it's out of the way and gives a nice feel to the steering.
Old May 18, 2010 | 11:07 AM
nkijkuit's Avatar
I don't think OME has one for the JK yet. Not in Europe that is. I did try a slightly modified TJ version but that one did not fit very well (got stuck under the trackbar bracket). I have the Rugged Ridge now. Looks a bit plain but works well.
Nils
