Tie Rod Ends/ball joints
Old May 17, 2010 | 09:47 PM
Yom's Avatar
Yom
Default Tie Rod Ends/ball joints
Hi all,
I am looking for the supplier of aftermarket HD ball joints which various suspension-bit manufacturers in the USA are using for their drag links and tie rods. Whether they come from the states or china doesn't matter, just need something better quality than the junk chrysler put on these vehicles.
Any help would be appreciated. Thanks in advance
Old May 17, 2010 | 10:03 PM
Millerman999's Avatar
RockKrawler.
Old May 17, 2010 | 10:08 PM
Yom's Avatar
Yom
^^ thanks - I am sort of looking to find the supplier rather than a distributor. Will see how I go though..
Old May 17, 2010 | 10:30 PM
Yom's Avatar
Yom
Original joints on mine lasted 6000 miles before they failed. That is, tie rod ends and axle C ball joints. Drag link boot had exploded with grease at the pitman arm end (and my vehicle has stock suspension) and the RHS tie rod end had the same fate (stock tyres!)
Even the brand new tie rod ends (apparently "revised" parts, they are visibly larger and different shape to the originals) have 1 to 2mm play in them when loaded up.
I reckon they're crap as my last vehicle's (also a Solid axled 4wd) had the same amount of play after 250,000 miles.
