TF lift on a Rubicon
Old May 21, 2010 | 03:19 AM
MatchStick's Avatar
Default TF lift on a Rubicon
I am looking at putting the Teraflex 2.5 coil spring lift onmy 2008 Rubicon 2 dr. The Teraflex website recommends using the stock shocks for Rubicons. I was wondering Why and what are the differences between the Rubicons and other Jeep suspinsions. Why would I not want new shocks?
Old May 21, 2010 | 03:35 AM
Doc_D's Avatar
I think they might be saying that the rubicon shocks with shock extenders work well (but not necessarily better than aftermarket shocks). I suspect that might be more true for a 4 door than a 2 door though. You'll get a full 3" of lift from the 2.5" coils on a 2 door. That could probably benefit from some longer shocks.
I went with OME LT shocks. Keep in mind though if you go with longer shocks like the OME LT shocks you'll get more axle droop which is a good thing. But I don't believe the 2.5" teraflex kit comes with the spring alignment spacers that the 3" kit comes with. Those help to get the top of the spring back onto the spring pad if you droop so far that they come off.
I actually started with a TF 3" kit but got 5+" of lift out of it. I ended up swapping the 2.5" coils and ended up with a true 3" of lift. I think this worked out really well for me because I got the spring alignment spaces and extended brake lines which I think are probably appropriate for a 2 door soft top running the 2.5" coils.
Old May 21, 2010 | 05:28 AM
daubie's Avatar
I have a 2008 2 dr Rubicon with a 2.5" Teraflex coil lift with Teraflex shocks and my buddy has a 2007 2 dr Rubicon with a 2.5" Teraflex coil lift with stock shocks with extensions. We have tried each others Jeeps to compare the ride and there is no difference in the ride feel. With the Teraflex shocks however I do get more droop when flexing than he does with the stock shocks and extensions
Old May 21, 2010 | 06:26 AM
Cedo Nulli's Avatar
I'm running the TF kit with the shock extension...love it. With the bump stops you're not going to over extend the stock shocks with the extension kit. The Rubi stock shocks are good nitro shocks, which is why they recommend keeping them.
Old May 21, 2010 | 04:04 PM
MatchStick's Avatar
So if I go with the stock shocks I will sacrifice some articulation but this is also somthing that can easily be changed later. I want to stay with a lift that will allow me to run 35's but I don't want to have to modify the drive line yet. The 3" lift that gives you 5" might put me in that positon. Unless I leave the HT on and change the front and rear bumpers what to do what to do
