dry start ticking finally stopped!
Old May 23, 2010 | 04:31 PM
DesignMonkey's Avatar
Default dry start ticking finally stopped!
switched from dino oil, to mobil 1 synthetic and various filters and still dry start up ticking. Just changed to royal purple and K&N filter and no more ticking!!! Royal purple throughout now - engine, and diffs
Old May 23, 2010 | 06:53 PM
Loadbreak's Avatar
Is this the first time you have used the K&N filter also?
Old May 23, 2010 | 06:57 PM
sixt7gt350's Avatar
I had startup tick with the K&N filter.
Old May 23, 2010 | 07:17 PM
nukeman's Avatar
I normally swear by RP oil and K&N filters. But not in my JK. For whatever reason, my JK doesn't like either. My startup noise was worse, and my service-based oil change notification would come on at around 1500 miles both times I used the combo.
I still use both in my other vehicles, but the JK is now exempt from RP/K&N.
Old May 23, 2010 | 07:18 PM
yes, tried the fram, mopar, purolator before - less running engine tic too so maybe more the combination or the oil. Use royal Purple only in my bikes - swear by it. reduced running temp on my harley.. just my preference
Old May 23, 2010 | 08:07 PM
PAS's Avatar
PAS
JK Freak, there was a service bulletin about the oil light coming on early, did you check that out by any chance?
Old May 23, 2010 | 09:19 PM
mikesjk's Avatar
I tried a K&N filter and after about 2 weeks I got the dry knock back. So I switched to wix and I haven't had a problem since then. Oh, I use royal purple as well ever since 3000 miles.
