best and least expensive lift (Complete package)
I am looking for the ( most complete and strongest) and least expensive lift lit I want to run 12.50 35's on my 08 rubicon. I have a heavy front bumper and winch combo already so my ride has some serious rake. I am considering an old man emu kit, and aev kit and maybe the full traction kit. Some other questions are what else do i need track bars ? I know I need drive shafts. I want to do those with the kit. I will likely run spacers until I can afford wheels.
Does any one make a complete package deal ?wheels, choice of tires, 3-inch lifts, drive shafts, and any other necessary items to complete the package. if so what does it cost?
Not sure where to start
Most complete and strongest + least expensive = not possible (antonyms)
There are many quality complete lift kits (2"-3") to fit 35" tires like Teraflex, OME, Rock Krawler, and others. Drive shafts may not even be necessary. Track bars and front lower control arms maybe. Do some more research.
$1774.99 + $25 shipping
Parts Included
* Front & Rear Drive Lines
* Front & Rear Coil Springs
* Front & Rear Shocks
* Front Track Bar
* Rear Track Bar Bracket
* Front & Rear Brake Lines
* Front & Rear Upper Control Arms
* Front & Rear Lower Control Arms
* Front Quick Disconnect Sway Bar Links
Product Details
# Engineered by Jeep enthusiasts with sportsmen and rock crawlers in mind.
# Trail Master coils and SSV shocks for a great ride on and off-road.
# .250 Walled DOM tube replacement upper and lower control arm with flex joint for maximum articulation.
# Replacement front track bar with heim joint ends for proper geometry and bind free movement.
# Standard quick disconnect sway bar links.
# DOT approved braided steel, Kevlar lined brake lines for front and rear included.
# Includes double cardan drive lines for added durability and reliable off-road performance.
# An affordable package for the off-road enthusiast.
# Fits 4 door JK X and Rubicon models.
# Easily accommodates 35” tall tires.
it's a trailmaster lift = 5" front & 3" rear
You should give David at Northridge a call. He knows his products and won't try to sell you something just to make a buck. Chances are good he may even be able to put a "package" together that best meets your needs (and the free shipping won't hurt either!)
I'd suggest you start with the FAQ's for some background. Get an idea of how you will be using it and which components 'you' will want/need, then start looking at lifts that fit your criteria. (know what the components 'do' so you can make an educated decision on each kit, instead of blindly listening to people on a forum who may have completely different uses for their jk's...)
These might be a good start:
https://www.jk-forum.com/forums/show...272#post211272
Q: What are all the components that I will need with a 3" lift?
Q: What is Caster? How much do I need?
https://www.jk-forum.com/forums/show...276#post211276
Q: What gear ratio should I be running with 35" tires?
Q: Is there a good chart that I can refference to help me determine what gear ratio I should have installed based on the tire size I am running and the RPM's that I hope to be running?
https://www.jk-forum.com/forums/show...327#post533327
http://project-jk.com/jeep-jk-write-...-end-alignment
There's a lot I don't know. I did read all the posts re what you need. I have figured out that I am going with 513's and new drive shafts , will run 35's now maybe 37's later . so I am trying to figure out whose kit works the best for the best price. For example if on one kit you have to add track bars brake lines and bracket and this that or the other thing but is only a few bucks cheaper. then i would probably go to the more complete lit to begin with something designed to work together form the the start. at least I think so now the more I read the more I realize i don't know. Johnny joints over bushings that I figured out. but this is alos my daily driver. so the search continues
I have the same questions. I've been lurking around here for a while and read all the lift posts.
I'm considering the Full Traction 3" premium lift as it seems the most complete (minus driveshafts).
Accordingto Full Traction, the 3" lift is an actual 3" lift (which is what I want) while according to posts on this forum the Teraflex 3" gives more like 4-5" lift which is to much.
I've been on the Teraflex site but must have missed the complete 3" lift.
I have a 2008 2dr Rubicon.
Take a look at our 4" X-series kit. I believe it is the most complete kit @ $1199 on the market. All 8 adjustable arms with x-flex joints, springs, shocks, discos, sway bar links, stainless steel brakelines, adjustabe front track-bar.
http://www.roughcountry.com/jeep_jk_4flex.html
See the info below on the premium plus, no MAINTENANCE kit. This has everything you need for your 4 door JK. (minus front shaft),
As Always, Full-traction is made in the USA.
I'm not in the office, but if you send me a PM. I'll give you my cell number.
Full-Traction Suspension introduces the newest in a series of superior engineered suspension systems for the new 2007-2010 Jeep JK Wrangler. Combining all the necessary components together in a 100% bolt-on package, this system will allow use of 35"* tires with ease, give superior flexibility, improved ride quality, and most innovative, NO LUBRICATION MAINTENANCE! . Replacement front and rear upper control arms are manufactured from durable 1.5" x .188” wall DOM steel tubing and come equipped with fully serviceable flex joints and long lasting OEM style rubber bushings. This kit runs silent.
Quality laser crafted components allow proper fitment to make this system the one to choose for JK'ers demanding the best. System comes complete with heavy duty adjustable front & rear track bar track for proper axle alignment, new generation front sway bar disconnects, rear sway bar links, bump stops, off-set brake line relocation brackets, and ride frequency tuned coil springs for a comfortable ride. Detailed installation instructions included with step-by step photos.
* Using recommended tire widths & wheel backspacing
Part: FTS7153 4 Door/FTS7154 4 Door
Fits: 2007–2010 Jeep JK Wrangler
Price: 1199.95 plus FREE SHIPPING
Call today and place your toll free order. 877-757-9779
