OME Northridge Kit. What else is needed???
I am looking at the OME long travel kit from Northridge. It comes with SPRINGS, SHOCKS, FRONT AND REAR ADJUSTABLE JKS TRACK BARS. I want to put 35's on. Is there anything this kit is missing that will make things work/run right. Control arms, bump stops, brake line brackets, or new brakel lines. What is necessary?
Also I have a Rubicon with the electronic swaybar disconnects. Will these be affected.
I would buy adjustable sway bar links as well, and if your getting the long travel kit as you say I would also get extended brake lines. You might want to think about beefing up the rear axle trackbar mount as it is a weak point on the JK. I have the JKS one, it's very nice and welds on but won't correct your roll center. I hear the teraflex one is great and it bolts on. Happy purchasing!
Are you sure you are looking at the OME Long Travel kit??? And not the regular ome with added trackbars...
Listed at $1499
http://www.northridge4x4.com/proddet...OME-LT-JK-LIFT
Or go to this one and build your own...
http://www.northridge4x4.com/proddet...E-LIFT&cat=272
Listed at $1499
Old Man Emu Long Travel Jeep JK Wrangler Lift Kit. Comes with standard or HD coils, JKS Front and Rear Trackbars, long travel shocks, adjustable swaybar links, bump stop extensions, extended brake lines and adjustable front upper control arms.
The ome kit from Northridge has all the options. . Control arms,brake lines, coil retainers, bump stops, n links. Call Dave he will set u up. Control arms r Tera or currie I believe.
Sent from my Droid
Sent from my Droid
Listed at $1499
Listed at $1499
If you are putting the LT shocks on plan on buying a front driveshaft or cutting your crossmember.... I have had to do both
Just explain to Dave what your tryin to do and he will help guide you in what steps to take
Definitely give David a shout. He's legit and will set you up.
If you have the cash, I'd recommend doing it all and doing it right from the start.
Control arms really improved the ride so they'd get my vote. With the long travel you'll need the extended brake lines (or brackets) and bump stops.
Check with David about sway bar links. You'll need them and make sure you'll have clearance for your stock wheels vs new links. If not you'll need spacers or new wheels.
If you're going to add a front bumper and/or winch, add a front spacer in now to help with the sag from the extra weight. You'll save time having to pull out the front coils down the road.
Chickenman you just like to flex.
