Use an unlimited driveshaft on a 2dr with a lift?
Old Jul 17, 2010 | 10:20 AM
Wartoy's Avatar
Default Use an unlimited driveshaft on a 2dr with a lift?
Maybe this is a completely stupid question.. but!
Ive done a lot of reading on here and i understand with the 2dr, its highly recommended to replace the driveshafts if youre lifting more than 2.5".
Now my dad just lifted his 4door, and replaced his driveshafts for it, so hes still got the old ones lying around. Would it be possible to use his unlimited (longer) driveshafts for my 2door if i lift mine?
If it IS possible, is there a certain lift height that those would go with?
Old Jul 17, 2010 | 10:50 AM
Jeeperman13's Avatar
if i was you, id find out how long the new Drive shafts are supposed to be, sounds ike a half decent try to me....
Old Jul 17, 2010 | 11:27 AM
capt scotty's Avatar
When you lift the JK the length of the drive shaft is not the big problem. It is the angle of the driveshaft the eats up he OEM joints.
Old Jul 17, 2010 | 01:07 PM
Full-Traction Suspension's Avatar
Former Member
Originally Posted by GoodysGotaCuda
Yep .
x3 or so..
the Unlimited way to long for the two door anyways.
Old Jul 17, 2010 | 01:59 PM
Wartoy's Avatar
Okay thanks for the info. So new driveshafts are the only way to go then
