need tire ideas for a jk with 6 inch susp. lift 2 inch body lift
alright, got a 4 door, gonna do a 6 inch rough country lift with a 2 inch body lift just for sh*ts n grins, when i get back from iraq, but finding the right tire is like trying to find leprechaun in the desert, i need ideas, im trying to go big, i was looking at some pitbull rockers 39.5x16.50 on 17s but they require a 17x12 wheel which i cant find, does anyone know of a tire that is large in size, but will manage to work on stock wheels ( i kinda like them) 17x7.5 or know where i can find cheap tires and wheels, please dont judge me on being a cheap ass, i have alot of money goin into my jk and trying to pinch pennys where i can, i mean government pay aint that wonderful haha any help please
Cheap tires and wheels in that size are very hard to come by. Wish I had better advice, but check into Pro Comp or cragar steel wheels. I know thew also make 15x10 and even 15x12.
Are you planning on running that front D30 with those 39.5x16.50's, or will you be upgrading to a stouter axle? If you are upgrading, check into what the bolt pattern is going to be before deciding on the rims...
You might also look at flat fenders and bumpstops instead of the body lift?
6+2 inches of lift is a ton for 39.5s
U might be pretty tippy
I'm on 3.5 running 37s and I'm going to see what I can do to run 39.5s without lifting it anymore
haha i know, i stand an amazing 5ft 7 inches, lol my fiance is something like 5ft 3in ima hafta toss her up in then go around n act like its a jungle gym, but if your gonna do something, go big and do it right
You will also want to be changing the diff ratios or you wont be going any where real fast!
If its a 2010 model the 16 inch options I believe will be no go, should be the same as the down under versions with bigger front brakes? We cant fit anything under 17's any more.
One other thing I would be concerned about is fixed control arms, I think the RC kit has fixed LCA's. If you like the RC lift just buy some adjustable LCA's. I wouldn't cheap out to much at the height you are looking for. I can't imagine what I death wobble would feel like at 6"s.
I definitely would not do the body lift. Especially not just for "sh!ts and gr!ns". For one thing, you don't need it. Two, over 1" body lift causes shifter problems. And three, you'll create a lot more wheel well, bumper, and other issues than you need.
As has otherwise been stated, you can fit 39"s with a 6" and flat fenders easily.
