Pls help I want a 4" or 5" lift
I have a 2 door 2008 jeep wrangler and would like to get 4" to 5" lift but I really don't want to buy new drive shaft . Pls let me know if I would I have to or can I just put the lift on pls help me I'm new to wranglers plan on puting 18" rockstars and 35" nitto mud's
With 35" tires you really don't need a 4" or higher lift. A 3" lift might be fine. Pretty much anything over 3"s of lift will eventually need new drive shafts. You may eventually need them with a 3", but you wouldn't need them near as soon.
You can run that set up with out that much lift... you only need 2.5 inches and then you dont have to modify much.. but if you plan on doing the rubicon trail and wheeling the hell out of her... youd better have some cash and go with the bigger lift with 37's or bigger of course! But.. that means adding a lot of new stuff! J.E.E.P. Just Empty Every Pocket! Have FUN... CHEERS!
You don't need a huge lift to run 35's. If you HAVE to have a tall lift, be prepared to buy both adjustable ca's and driveshafts. It isn't rocket science: tall lift = more components. You may not need them right away, but plan ahead and set some money aside...
Have you considered the TrailMaster 5" lift? It comes with new drive shafts. Just installed one on my 2008 2 door X and love it. Went with 37s.
