Do you have to use an additive when locker?
Old Jul 22, 2010 | 04:01 AM
dlincoln91's Avatar
Default Do you have to use an additive when locker?
Im getting ready to put my differential covers on and was wondering do i still have to use the additive for my front auburn locker? Im going to run a good synthetic in it but i am hoping i do not have to use the additive.
Thanks
Old Jul 22, 2010 | 04:08 AM
Yankee's Avatar
I thought the additives were used for limited slip, not lockers?
Old Jul 22, 2010 | 04:16 AM
Lotus03's Avatar
i have to put on new diff covers and put in synthetic also. What is additive for?
Old Jul 22, 2010 | 05:05 AM
GoodysGotaCuda's Avatar
No additive needed for a factory locker. There is an aftermarket locker that I understand uses a clutch limited slip (unsure which brand), that probably needs the additive)
Limited slips need a limited slip additive to allow the clutches to slip easier. Most synthetics incorporate this.
Old Jul 22, 2010 | 07:59 AM
Dynatrac's Avatar
Sponsoring Manufacturer
The REAL answer is yes, you need a friction additive with an Auburn unit. They recommend Ford, GM or their own ONLY. The Auburn Ected has clutches which require the additive. The additive is used to prevent clutch chatter (noise). The also very clearly state- DO NOT USE SYNTHETIC OILS.
The factory Rubi electric locker does not require additive.
Old Jul 22, 2010 | 02:28 PM
dlincoln91's Avatar
Sorry, yeh i have an auburn and i was told by some mechanics that synthetic oils would cover the additive part for the clutches.
When i change my covers next week i will have to buy new additive i guess.
So where can i get it?
Old Jul 22, 2010 | 02:58 PM
Dynatrac's Avatar
Go to your local GM dealer and ask for friction modifier for the factory LSD. It should be under part number 1052358. Remember- Do not use synthetics.
Old Jul 22, 2010 | 03:01 PM
dlincoln91's Avatar
would it be stupid to just re use the oil it has only been in the hub for maybe 1000 miles
Old Jul 23, 2010 | 08:31 AM
JKU Rubicon's Avatar
Risky thing
Don't take chance, just to save 20$...
Old Jul 23, 2010 | 08:37 AM
MANUAL:
198 RBI (Model 35) and 226 RBI (Model 44) - MOPAR Gear & Axle Lubricant
(SAE 80W-90) (API GL-5) or equivalent. For trailer towing, use MOPAR
Synthetic Gear & Axle Lubricant (SAE 75W-140) or equivalent. Models
equipped with Trac-Lok™ require an additive.
There is nothing about the True-Lok stock lockers
