1" M.O.R.E body lift to reduce floor heat
Anyone done this? I have an excessive amount of heat on my floors, so much that it melted my Quadratech Floor liners in the rear and a shoe on the trip back from Moab. I did relocate the Magnaflow 44 under the drivers seat, but there is heat shielding there. I guess just not enough.
So the body lift will give me an extra inch of clearance for the tires (consider this a bonus), and maybe reduce some of this heat (letting more air pass over exhaust).
Also going to look into attaching some heat shielding material to the bottom side of the carpet to help reduce the heat.
Thoughts, suggestions???
Sponsoring Manufacturer
Hypertech Representative
Floor & Tunnel Shield - Heat & Sound Insulation
SKU: 050501
Floor and Tunnel Shield was designed to withstand direct temperatures up to 1750°F. Because of it’s unique material, it is capable of insulating against unwanted road noise up to 50%.
Constructed utilizing an embossed 10 mil aluminum face bonded to a 1/8” composite fiberglass insulation, Floor and Tunnel Shield is backed with an aggressive adhesive that holds past 450°F. Only 3/16” thickness it requires minimal clearance and can be shaped and trimmed for a custom fit.
Floor and Tunnel Shield provides the optimal way to reflect heat away from vehicle components and perfect for protecting under hoods, firewalls, fuel cells, exterior areas such as transmission tunnel, floorpans and other under-vehicle locations.
This is what I would use
SKU: 050501
- Excellent heat and sound barrier
- Withstands 1750°F direct continuous heat
- Self adhesive backing for easy installation
- Unique material works in harsh environments
- Can be trimmed to fit any shape
Paint wont change enough if your melting stuff in your cab, you could also use this for a extreme case.
Exhaust Wrap - Black
SKU: 010120
Wrapping headers and down pipes is an important first step in controlling unwanted underhood radiant heat. Keeping exhaust gases hotter within the exhaust system helps in decreasing exhaust density and increases exhaust flow. This improves exhaust scavenging resulting in cooler air intake temperatures for an improvement in performance and a gain in horsepower.
Design Engineering stainless steel Locking Ties are the perfect way to fasten exhaust wrap for a easy, clean and professional installation.
SKU: 010120
- Reduce under hood temperatures a realistic 50%
- Improves horsepower
- Withstands 1200°F direct/2000°F radiant
- Only exhaust wrap with installation guide lines
- Added durability and heat retention
The vendor may be able to offer more information but from past experience the wrap will make a nice environment for rust. I've had a couple of sets of headers (non-Jeep vehicles) that rusted through long before their time becuase of fiberglass wrap. That was a decade ago and products may have evolved since then. Just a thought for what it's worth.
