Un-even tire wear!!!
Old Aug 10, 2010 | 07:30 AM
derekjm14's Avatar
Default Un-even tire wear!!!
So, I noticed my front end is wearing my tires more on the outside than the inside. I already rotated the tires, but now I need to figure out what is causing the wear. Does anyone have any suggestions on what to check and how to check it? I have a rough country 2.5" lift with only springs and shocks. I never had the alignment done after the lift because it seems to drive fine after adjusting the steering. Anyway, any suggestions would be greatly appreciated!
Old Aug 10, 2010 | 07:45 AM
Dr.McNinja's Avatar
Get it aligned. You probably have the tires toed in too far. Nothing else on the lift would be that drastic.
Old Aug 10, 2010 | 08:01 AM
nthinuf's Avatar
http://project-jk.com/jeep-jk-write-...-end-alignment
derekjm14's Avatar
Do I need to take it in or can I adjust the toe-in myself? I read over the write up and it seems pretty simple.
Old Aug 12, 2010 | 05:18 PM
jantonix's Avatar
You simply need a wheel alignment properly done for oversized wheels to fix that problem, a wheel alignment is a must about 1k kms after a lift is installed.
Old Aug 12, 2010 | 06:52 PM
Biff Malibu's Avatar
Getting an alignment done is a waste of Money. Other than the caster, a lift doesn't change anything but the steering wheel position, which can be adjusted in a few minuets with little to no mechanical skills
