Rubicon Express Radius Long Arm Kit
Anyone know where i can get just the radius long arm kit and not the springs and everything else?
I have looked all over and havent seen anything on just the long arm. Any help is appreciated.
so you are just looking for the arms basically and mounts??
if so, they sell individual parts, but they are very pricey when bought that way. call re and see what u can work out
this is the 4.5" long arm kit
RE1143 - GEN2 DISCONNECTS 3.5"-5.5" JK $124.95 (these are junk, i replaced w/ JKS)
RE1157 - JK REAR SWAY BAR LINKS $29.95
RE1372 - JK 4.5" 4DR / 5.5" 2DR FT COIL $174.95
RE1377 - JK 4.5" 4DR / 5.5" 2DR RR COIL $174.95
RE1380 - BUMPSTOPS 2" FRONT LOWER $32.95
RE1387 - JK REAR 2" BUMP PAD $40.95
RE1530 - JK FRONT BRAKE LINE SET-24" $119.95
RE1540 - JK REAR BRAKE LINE SET - 20" $119.95
RE1607 - JK REAR LOWER TRACK BAR BRKT $79.95
RE1675 - JK FRONT TRACK BAR BRACKET $89.95
RE1680 - JK FRONT EX DUTY ADJ. TRACK BA $179.95
RE2610 - JK CHROMOLY DRAG LINK $199.95
THIS MIGHT BE WHAT U ARE LOOKING FOR
YES YOU HAVE TO HAVE THE FRONT CROSSMEMBER ASSY, THE FRONT ARMS BOLT INTO THIS, AND U HAVE TO HAVE THE REAR CONTROL ARM MOUNTS, THESE ARE WELDED ONTO THE OUTSIDE OF THE FRAME REAR WITH ARMS BOLTED INTO THEM
RE4070 - JKLA FRONT LEFT LOWER ARM $320.95
RE4075 - JKLA FRONT UPPER ARMS $229.95
RE4080 - JKLA FRONT RIGHT LOWER ARM $320.95
RE4085 - JKLA REAR LEFT LOWER ARM $320.95
RE4090 - JKLA REAR UPPER ARMS $239.95
RE4095 - JKLA REAR RIGHT LOWER ARM $320.95
RE4520 - JKLA FRONT CROSSMEMBER ASSY $478.95
RE4525 - JKLA REAR CONTROL ARM MOUNTS $229.95
TOTAL: $2,462.60 (ONLY THESE 8 ITEMS)
TOTAL KIT COST: $3,299.95
id be willing to bet, this is how re will make u buy the parts, individually. personally, i would go another route because of the money, i do have the entire lift (4.5" la) and very happy with it,
edit: the part names, part #, and pricing are direct from rubicon express website.
Yeh basically i just want the radius long arms and mounts and nothing else.
I just really like the idea of a radius long arm and want to run one but i dont see many companies having them over a traditional 4 link long arm
