I installed a Gauge and switch center top console, very nice...
Old Aug 14, 2010 | 12:27 PM
RyanBlack321's Avatar
Default I installed a Gauge and switch center top console, very nice...
Just wanted to share my new Console top. It houses 2" gauges, I used the AeroForce Tech Gauges and a total of 4 Rocker Switches.
I got it from RKC4x4.com, this was the best idea I could find to mount my gauges... The cop 4x4 was just too expensive and Im not a carbon fiber fan.
This was top notch quality and install is easy.. I did however go get some allen head screws to replace the ones they sent since I felt as though these would look nicer than the ones provided. That RKC on the top of the gauge console is just a sticker so it can be removed....
Here are some pictures....
ID:	82004   Click image for larger version
ID:	82005   Click image for larger version
ID:	82006   Click image for larger version
ID:	82007   Click image for larger version
Old Aug 14, 2010 | 12:34 PM
JERSEYJK's Avatar
Sweet! Very nice. Just wondering if it will obstruct your view of the passenger side front while crawling?
Old Aug 14, 2010 | 12:53 PM
I drove around with it and it did not seem to block my view... no more than my high lift jack thats on my hood..
Old Aug 14, 2010 | 12:55 PM
tlags24's Avatar
Very nice... Thinking of doing something similar
Old Aug 14, 2010 | 01:15 PM
ohlhockeyguy's Avatar
What are the gauges?? Looks nice.
Old Aug 14, 2010 | 04:29 PM
The gauges are the Aeroforce Tech gauges... They plug into your OBD II port (computer).. It can monitor everything that your computer monitors... makes for easy install and can monitor numerous different parameters.
You can also control your fan, idle, ESP, reprogram tire size and tire pressure monitor, swaybar disconnect light and more...
Old Aug 14, 2010 | 04:33 PM
robin's Avatar
that looks great!!
Old Aug 15, 2010 | 02:03 AM
Airhawksix's Avatar
Looks good Ryan, you are going to make me spend more money....Just empty every pocket ( JEEP )
Old Aug 15, 2010 | 03:14 AM
jmill012's Avatar
Looks good!
Old Aug 15, 2010 | 04:07 AM
08RedRecon's Avatar
Those look great. Best ones Ive seen yet.
