Newbie Tire Question
Old Aug 15, 2010 | 04:24 PM
Skeebo98's Avatar
Default Newbie Tire Question
I have an question about tire width. Can you put 32 inch tires on an stardard 18inch rim?
Old Aug 15, 2010 | 04:27 PM
OFCRyan's Avatar
Default Re: Newbie Tire Question
Depends on how wide you go. If you search for stock rim widths you'll find a thread about it. I'm running 285/65R18 tires on the stock sahara rims with no problem. Not sure what your looking at or what tire size you want but check it out.
Old Aug 15, 2010 | 04:29 PM
Biff Malibu's Avatar
The Sahara's tires are almost 32" stock. I had 35's on my Sahara wheels with no issues.
Old Aug 15, 2010 | 05:36 PM
Skeebo98's Avatar
OK...Thanks!
Old Aug 15, 2010 | 06:10 PM
nthinuf's Avatar
Look at the specs for the tires you are getting, it will list the recommended rim width range. Then talk to your installer. Some will not mount wide tires on narrow rims.
You can also look in the Wheels & Tires FAQ for all the info on the stock rims.
