fabricating my own winshield light bar
1/8 inch tread plate
made a cardboard template traced it on the metal with a silver pencil
cut it out with a plasma cutter....found it on craigslist 250 bucks
cut out the reverse for the other side
before you put them on the jeep put masking tape or something else on the jeep to protect the paint cause you will be putting them on and off alot till you get the bend just right
draw lines on the back where the bends will beging and end....score it with a cut off wheel on your grinder it will help you bend the 1/8" plate easier
put it in a vise and start to hit with a deadblow hammer and start to make the bends this will take awhile to figure out the first one but second one is much easier
once you have the bend then you can do some measurements and figure out where the holes need to be drilled "after you figure out where to drill use a small drill bit and hold it up to make sure you you measured correctly then drill with bigger bit
after both sides are done its time to figure out how high you want your light bar cut the section
i made it a little longer at the winshield so you can work the metal and then you can cut it to the right length later
cut the angles with a chop saw then weld it up
if you dont like the sharp look of the 90 degree angle the cut a cresent shape out of the corner
then you can heat it up and bend it around with a hammer and it will make it round which i like it that way thats totally up to you
after you get it rounded off the cut off the excess i left an inch before the bend starts
do the other to match
measure where you wat the light bar to attatch to the bracket you made then tack weld while on jeep do not weld it fully on the jeep you will blister the paint....oh i laid some towels on the jeep hood so if i dropped anything it wouldnt scratch it.....take off the bracket and finish welding it
the hard part is getting the winshield angles right on both thats why you just tack it then adjust it the finish welding
once the you have it welded and it looks like you want it then cut the 90 degree cuts at the top of the bracket
well i ran out of time this weekend I ordered the lights that i wanted so next weekend i can do the top bar and the tabs
i will finish the write up next weekend
6 hours invested so far
Hella 500 Black Magic Driving I like that black look.....so this is what im going with right now and later i will move them and probably go for the lightforce 140's when i can afford them....just got new whells and tires....pics to come
