Death Wobble... Really need help
Ok so i have been experiencing some Death wobble for some time now. It has been stable between 35 and 45mph, but my guess is that this is due to a lightly bad alignment and my worn out tires...
I have a new tie-rod and set of tires waiting to go on this week so hopefully that will help....
THE NEW PROBLEM:
About a week ago i started to get wobble at 50-65 ASWELL.... but its not constant, it will happen, then it wont.
Tonight i was driving on the highway and it started at 35 stopped at 40 as usual but THEN it started at 50 and was uncontrollable till i pulled over after getting up at 65mph.
I checked some thing out while i was pulled over:
-my track bar seemed to have a little play in it
the only thing that i have done around the time of this starting was putting on a Skid row engine skid and i don't think that has anything to do with this new found problem.
other problems, that may be related
--there is a sound coming from the wheels, possible needed wheel bearing
--there is a click/bang when i take off and stop some
I really appreciate any input on my issues....im supposed to be going to Rausch creek this coming weekend,,,and i need to get as much fixed as i can
THANKS IN ADVANCE GUYS!!!!
THE NEW PROBLEM:
Read through this one if you haven't done so already.
https://www.jk-forum.com/forums/show...es-and-Wobbles
when i checked it out, it has play on the axle end and its not back and forth, its tight, but seems like there is some weird movent in the joint... im going to take it out tomorrow and check it out
by the way it is a superlift adj trackbar, just for the record
I feel like balance and alignment problems will cause the wobble all the time not sometimes. but i could be wrong
I have never been able to accelerate through a death wobble, and the two times I tried it just got a whole lot worse. Vibrations from tire balance I've certainly been able to accelerate through, but far different than full on death wobble.
It sounds as if you have already identified two contributing factors to death wobble and there isn't much sense poking around looking for others until you remedy them. If you wait long enough, I'm sure they will start tearing some other stuff up.
on my rubi i had death wobble but it was because the tires were so un balanced and could be balanced. that took out the ball joints which the dealer re-did under warranty then some new tires and no more death wobble
Toad is right
Wobble is an oscillation (issue) coming from the wheels
Death wobble is an oscillation coming from the direction parts (trac bar, ball joints, allignment, etc)
You have to read this https://www.jk-forum.com/forums/show...es-and-Wobbles
