New Trail Master 3" Lift
Old Aug 16, 2010 | 02:10 PM
JK703's Avatar
Default New Trail Master 3" Lift
So I was on Quadratec today just surfing the new stuff that came out in this summers catalog. I saw this 3" lift kit by Trail Master for $320.00
Here is the link
hxxp://quadratec.com/products/16106_201.htm
Just wondering if anyone has purchased this. What the installation is like. And if it is worth getting. I don't do a lot of rocks. Just mud beach and logging roads, but putting 34" DuraTracs on so need a lift. For $320 it looks nice.
Thanks
Old Aug 16, 2010 | 02:46 PM
grady's Avatar
Default Trail Master
If you are already running a 2.5 inch bb, why would you spend that kind of money for another 1/2 inch of budget boost? You need to jump on up to a spring boost if you are going to spend the bucks. Just my 2 cents. When I get the money saved up I am going to go with a 4 inch teraflex. I reread your post and you dont have the Teraflex bb checked off. My bad. I think I would go with the Teraflex unit myself.
Old Aug 16, 2010 | 03:52 PM
nthinuf's Avatar
It's a BB with extras.
No caster correction, and the same front driveshaft issues as everyone else with a lifted auto...
For the installation, look at any of the write-ups in the suspension write-ups area. Same steps, whether it's a coil or spacer lift. Then open the DIY alignment one to adjust that front adj trackbar.
Old Aug 16, 2010 | 07:30 PM
JK703's Avatar
Yah man its just hard to see all these other lifts that are cheaper and in most things if you shop around you find a cheaper product that is just as good but so far from everyone TF is the way to go.
Old Aug 16, 2010 | 07:31 PM
JK703's Avatar
What front drive shaft problems? I thought if you stayed in the 2.5-3" range there were no drive shaft issues?
Old Aug 16, 2010 | 07:58 PM
Pluke the 2's Avatar
there are a few that report ds issues with their 2.5 kits..
Old Aug 16, 2010 | 10:08 PM
nthinuf's Avatar
Flex it and check the clearance after the install. If it is anywhere even close to the crossmember skid or the corner of the tranny pan, see post 6 in this thread:
https://www.jk-forum.com/forums/show...vs.-Skid-plate
You will also want to keep an eye on the rzeppa (tcase end of the shaft). It will be pinched from the angle and may start spitting grease. They are not serviceable, so once the rzeppa or a torn boot start losing grease, it's just a matter of time. a few people have indicated that they are manually greasing the shaft to prolong the life, but...
Old Aug 17, 2010 | 08:10 AM
JK703's Avatar
Thanks for that thread. So basically if I do the 2.5" I need to cut a notch 5x2" off of the skid plate. Then replace that clamp thing with a zip-tie and I shouldn't have to worry right?
Old Aug 17, 2010 | 10:32 AM
nthinuf's Avatar
Depends on how much actual downtravel you have. People that disconnect and have longer travel shocks are more likely to run into contact issues than people than don't disconnect and have shorter shocks. Best advice is to flex and check
Also make sure your front axle is centered. If it is off to the passenger side to far, the driveshaft is moved closer to the tranny pan.
Old Aug 17, 2010 | 12:35 PM
JK703's Avatar
Alright thanks for the advice man. Yah I won't be disconnecting. But the lift is going to be going on this Fall the stock tires are almost done.
Another quick question. I know a lot of people on here run Wheel Spacers, but I was talking to a couple friends from PA and they have driving jeeps their whole life and told me to stay away from wheel spacers because of the tendency to break which would screw you. Now is that them talking about older technology and not knowing the newer wheel spacers strengths or is it personal preference?
