ordered 35s,they better fit,lol
i have a 2.5 terraflex coil lift,i have 33s ,but they are too small,so i ordered 35s actually they are 315s ,i made a post on here and people said they would def. fit, i have 17x9 rims with 4.5 backspacing v tec raptors from discount tire,and am putting on 315x70x17 tires,i hope they dont rub when wheeling ,what do you guys think ???
You should be fine when wheeling. I've got a 2" lift and I only rub a little at full lock out.
I think the 2.5 TF lift actually gives 3.5" of lift so you should be just fine. You will definitely need to remove the front air damn though.
What kind of rubber did you order?
Also, I've heard 2.5" is enough lift to fit 35's without a problem. The JK's should just roll off the line with'em anyway.
