Superchip and TPMS
Old Aug 30, 2010 | 01:03 PM
db1's Avatar
db1
Default Superchip and TPMS
I just used my Flashpaq for the 1st time yesterday. I didn't see where to make the adjustments to the TPMS.
Any suggestions?
Old Aug 30, 2010 | 02:45 PM
mpkelley20's Avatar
Any suggestions?
The feature is listed under advanced options/features on the programmer. But before you give it a whirl, you should download the TPMS shut off feature...
Once you hook up the programmer to your Jeep the first time, bring it back inside, hook it up to your computer, let your stock info upload and check for updates. Once its is all done doing its thing, you SHOULD be given an option before the program closes to download optional features through a store front that pops open on the computer screen. Select the TPMS diable feature and it will install to your programmer.
Connect your programmer back up to your jeep and go under advanced features/functions (can't remeber what its called) and you should see a setting for TPMS adjust and/or shut off. That feature should actually already be there to adjust (not turn off). For some reason Superchips makes you download the shut off feature as it doesn't come pre-loaded. The only TPMS feature that comes preloaded is the ability to adjust it down to something like 20psi. At least the additional feature if free!!
Oh, and can I assume you want to shut it off because you just got some nice 35's??!!!!
