How high, Unlimited
It is my understanding that around 4" of lift is the "gray area" where drive shafts and compensation for suspension geometry may not be strictly necessary but starts becoming a good idea to do.
That said, with my 4" Teraflex lift I went ahead and did both drive shafts, adj front & rear trackbar and the draglink flip
I have a 3" OME lift and although both shafts seem to be OK, it looks to me like they are at enough of an angle that the cv joints at the TC are having to work a lot harder than when stock. This tells me to start looking for replacement shafts. Sooner, rather than later. I only have about 3000 miles since the lift and 5000 miles total. I will have new shafts before 10,000.
TF 3"
Front shaft boot ripped when wheeling
The front shaft angle at the transfer case was very steep and would have led to premature wear
I also know people that wheel with 2.5" lift and ripped there boots, although a ripped boot isnt the real problem if it stays greased. But the severe angle will affect something
