Coil spacers / body lift and shock suggestions
Old Sep 7, 2010 | 05:03 PM
Jeepfaust's Avatar
Unhappy Coil spacers / body lift and shock suggestions
I have a 2007 JK Unlimited with a 2 1/2" Sky Jacker Lift on 35" tires, need new shocks and I want a little more height.
So here are my questions:
1- Should I get 2" or 3" Coil spacers or go with a 2" Body Lift?
1.1 What are the ramifications and or additional modifications that i will need to accomplish either of my height objectives?
2- I need new shocks and the current shocks cause a washboard like pitching and rolling when I mildly to heavily apply the breaks. I assume the shock rebound/bump is not correct, hence the dangerous rocking of the front end when stopping mildly to strongly.
What are the suggested settings for new shocks if I go with either the Coil Spacers or the 2" Body Lift?
Thank you in advance and I await your sage advise.
Old Sep 12, 2010 | 08:18 AM
Jeepfaust's Avatar
Default bump
Any thoughts?
Old Sep 12, 2010 | 08:26 AM
Pluke the 2's Avatar
if you want to do it right. you should buy a complete kit with coils, shocks, brake line extensions, front and rear trackbars, adjustable control arms, spring retainers, bump stop extensions.
Old Sep 12, 2010 | 06:17 PM
opie2nd's Avatar
The body lift route should be a last resort, I have personally removed two from previous Jeeps. It stretches out your hard brakelines, your shifter and your fan shroud which can effect cooling. Look for a decent full suspension kit (coils, not spacers, shocks and bracketry) many are out there for 4-6 hundred.
Old Sep 12, 2010 | 08:52 PM
Jeepfaust's Avatar
Excellent thanks guys 400-600 is not a big deal.
