Rock Krawler Advice Needed ASAP
Old Sep 9, 2010 | 06:29 AM
GaMtnJk's Avatar
Default Rock Krawler Advice Needed ASAP
RK is running a prettty good sale (Check it out here https://www.jk-forum.com/forums/foru...p-Vendor-Forum)
I plan on running 35's for sure and maybe flat or trimmed fenders.
Would y'all recommend running the 2.5'' which can be tight without the flat fenders or the 3.5'' which might make 35's look small with flat fenders? The RK guys recommend the 2.5'' but I am slightly torn. HELP!!
Old Sep 9, 2010 | 06:36 AM
tslewisz's Avatar
How soon do you want to buy driveshafts?
Old Sep 9, 2010 | 06:40 AM
GaMtnJk's Avatar
not until I absolutely need to, as in out of necessity do to abuse, not lift requirements. I have an automatic by the way
Old Sep 9, 2010 | 06:41 AM
CTNEDGE's Avatar
You have a 4 door so DS's won't be an issue soon as long as you don't slide your front across a rock! Personally, and from what I have seen most everyone on here do which is always want bigger, I would go bigger first. 35's will look fine and you will already be set up for 37's when the bug hits...
Old Sep 9, 2010 | 07:13 AM
Pluke the 2's Avatar
personally, if I had a four door. i would get a 2.5" kit + flat fenders+ 1" bl + bump stops and run 37's
four doors and 35's just look so little.
and on the driveshaft thing. it's going to be an issue with automatics. not two door or four door, unless you're going over 3"+ in net height. . . than the rear shafts will start to fail eventually over 4" .. .
Old Sep 9, 2010 | 07:35 AM
GaMtnJk's Avatar
Does the lift added by the BL cause DS issues or is it strictly suspension lift?
Old Sep 9, 2010 | 07:46 AM
Strictly Suspension will cause DS issues.
