Front Axle Housing Reinforcement
Old Sep 10, 2010 | 10:38 AM
AndyM's Avatar
Default Front Axle Housing Reinforcement
How imperative is it to reinforce the stock Rubicon 44 front housing? I've read that this is a weak link. I have an '08 Unlimited which I just lifted (AEV lift) and I am running 35s. The jeep has been to Moab in stock form and sees regular trail use, but not abuse. I have a '68 Jeepster with Dana 60s and 37s for hard-core trail use.
So, do I spend the effort to yank the housing and install a reinforcement kit or roll it as is and avoid abusing it?
Last edited by wayoflifette; Sep 10, 2010 at 10:43 AM. Reason: edited blacklisted company
Old Sep 10, 2010 | 11:20 AM
porters's Avatar
With 35s you better get Sleeves and Gussets ASAP.
Old Sep 10, 2010 | 11:34 AM
rutdigger's Avatar
I will agree with the Gussetts, but not the sleeves. He stated he does not abuse it and doesn't take it on hardcore trails. You really gotta be going after it to break an axle housing. The Bending of the Knuckle would be alot easier to do. So, I would agree on the gussetts. That will be my next mod on mine before the gears. Did my buddies last week.
Old Sep 10, 2010 | 12:27 PM
robin's Avatar
I agree with this a 100% I don't see the need for sleeves.
Old Sep 10, 2010 | 01:09 PM
AndyM's Avatar
Thanks guys! I figured that was the case. Time to break out the welder. Whose gussets are preferred, or are they all the same?
Old Sep 10, 2010 | 01:28 PM
porters's Avatar
If your in the neighborhood, you might as well do the sleeves as they are not that expensive.
Old Sep 10, 2010 | 01:49 PM
Fly-Attack's Avatar
Not to hi-jack.....but what is involved to install the sleeves?
Can it be welded up with the housing left in the jeep, axles and hubs pulled?
Old Sep 10, 2010 | 02:01 PM
porters's Avatar
You pull the axle shafts, drill holes on the tubes, clean out the debris, slide in the sleeves, and then plug weld the holes you drilled earlier. Removing the axle makes it easier to drill the holes, but I would not say it's required.
Old Sep 10, 2010 | 02:08 PM
Fly-Attack's Avatar
Any idea of how many (holes/plug welds) and where? Could they all be done down the front edge of the housing?
Old Sep 10, 2010 | 02:16 PM
porters's Avatar
For strength, you want to spread out the welds so they are all over the tubes, some in the top, some on bottom, and some on the sides. Here is a good thread on sleeve install.
https://www.jk-forum.com/forums/show...highlight=nemo
