teraflex control arms on a 2.5 inch coil lift?
so i installed the teraflex full flex arm kit on my 2 door jk and now the jks ajustable rear track bar hits the passenger side lower bump stop and spring? can these not be installed on the 2.5 inch coil lift? i am planning on going to a 4 inch lift just havent had the time to install it yet...
The problem is most likely the extended lengths of the upper rear CA to get your driveline/pinion angle nice...took the rear coil springs and rotated them towards the rear. It's common for this to happen.. Several fixes are the 10 degree rear coil wedges, or cut off the OEM rear lower coil spring perches..and install like the JKS coil spring perches..they attach to your axle tube and you can adjust to any angle you want. Thus it will eliminate the coil bowing out and hitting your adjustable rear track bar.
