looking to lift my 4dr jk 3''! is BDS a good lift kit? any suggestions?
i just bought a 2010 jeep jk 4dr sport, i want to run on 35s and looking at lift kits, after calling a few shops they offer BDS, but I am wondering if its a good suspension and if its worth it to pay $1100 install? also includes front stabalizer bar
If you haven't already seen the Sticky on the top of the Modified Section, it will help answer a lot of your questions.
https://www.jk-forum.com/forums/show...ery-Newbie-Has
What is a good 3" Suspension Kit? Well. Everyone's going to tell you something different. And, until you do researching on your own, you're never going to find a correct answer for your question.
From the link above:
Q: What are all the components that I will need with a 3" lift?
A: At bare minimum, you should have a set of 3" coils, bump stop extensions, longer shocks, rear brake line extension brackets, new longer rear sway bar links (factory links can be installed up front), adjustable front track bar and rear track bar relocation bracket. Optimally, I would recommend adjustable front upper and lower control arms as well as they will help you set your caster to the appropriate angle it needs to be. Also, if you have a 2-door, adjustable rear upper control arms and a new double cardin U-joint style drive shaft would be highly advisable.
They have installed a couple sets of our 3" Premium plus SRS lifts.
