Do i need flex arms with suspension lift?
Old Sep 13, 2010 | 06:32 PM
Rubicon2010's Avatar
Default Do i need flex arms with suspension lift?
i own a 2010 rubicon 4dr. i am seriously looking at buying the teraflex 3" lift kit but do i need the 8 flex arms to go with it? also whats the diff between long and flex arms?
Old Sep 13, 2010 | 06:34 PM
Serg5000's Avatar
You can lift you JK without changing any of the "arms"
Old Sep 13, 2010 | 06:40 PM
i have read reveiws and they said that they are baisically a requirement
Old Sep 13, 2010 | 06:47 PM
u-joint's Avatar
Yep, they are virtually required for almost everybody in some occasions
Seriously, you don't necessarily need them. I don't have them. I do plan on getting them, but if money is a concern these are definitely something that can be added later. Whoever told you they were "required" was either trying to sell you something or was speaking of much larger lifts (4+ inches).
Old Sep 13, 2010 | 06:53 PM
ok im trying to find a teraflex or better system that comes with the shocks and essecary arms all in the kit i also herd you dont need all 8 but it is prefered. i would like to find a pack that comes with everything besty quality but also low price
Old Sep 13, 2010 | 06:57 PM
i found one that is relativly cheap and i can get shocks with it and its under 2k can you tell me if it is worth it and if its everythig i need?
http://www.quadratec.com/products/16064_604X_PG.htm
Old Sep 13, 2010 | 07:02 PM
mkjeep's Avatar
I've been running a Tera 4in for almost a year with only front adj lowers, I have a 4dr. If u have a 4dr the rear ds will last a long time unless it takes a hit, then your done. I'm just now going to get the rear uppers and lowers cause I gotta change the rear ds do to a wreck. You can do the 3in, I suggest frt lowers with it. Your frt ds if you have an auto will be your first priority when it goes to spitten grease.
Old Sep 13, 2010 | 07:04 PM
Denny2565's Avatar
How much are you looking to spend? I've been very satisfied with my Trail Master 5" kit.
For $1,325 you can get a Trail Master lift kit complete with all 8 adjustable control arms.
Or for another $450, you can get the same kit with front and rear drive shafts.
Edit: I just saw that you posted while I was typing my comments. So it looks like either of the kits I suggested would meet your needs. But only if you're going with 35" or 37" tires. Anything smaller would look a little odd on a jeep with 5" of lift.
Old Sep 14, 2010 | 12:21 PM
With that 5" did u get shocks with the kit and how smooth does it ride.
Also I only have stock tires right now but looking to get 35's in future so maybe 5" is too tall. If you could recommend a 3" with everything at that price that would be great
Old Sep 14, 2010 | 12:25 PM
jdubb75's Avatar
Default Control Arms
Here is a very good explanation of what the arms do and when you need them. Kuddos to planman.
https://www.jk-forum.com/forums/show...=1#post1832861
