Why do I feel like I need a larger rear sway bar?
These are adjustable for a softer or stiffer rear swaybar.
Full-Traction now offers a replacement 19mm rear sway bar for use on Jeep JK models that are equipped with a lift kit or used while heavily loaded. The new bar is a bolt-in replacement for the stock bar. It provides increased roll stiffness through its larger diameter and is designed to reduce understeer/bodyroll while still being flexible enough for severe off road use. Recommended for all lifts of 3" and over. Comes complete with urethane pivot bushings and complete installation instructions.
